USB 3.2 Gen 1  3-Port Hub with Gigabit Ethernet
CSV-1430 The USB 3.2 Gen1 Hub 3 ports with Gigabit Ethernet is designed in a stylish manner and very slim which makes it easy to carry around.
The CSV-1430 allows you simultaneous access to 3 x USB 3.2 Gen1 ports and the Ethernet 10/100/1000 Port from just one single USB 3.2 Gen1 uplink.
The Device is downwards compatible to USB 2.0 standard, but this will have influence on the performance. The 3 USB ports are all USB Type A and USB 3.2 Gen1 compliant. The Ethernet port is compliant to Gigabit Ethernet 10/100/1000 (RJ45) and full duplex with flow control.
USB 3.0 Active Repeater Cable 10 m/ 32.81 ft Male/Female
Mini DisplayPort to DisplayPort Adapter
Support IEEE 802.3az (Energy Efficient Ethernet) Support IPV4/IPV6 pack Checksum Offload Engine (COE) to reduce CPU loading
It works with Windows and Mac OS X
Slim design makes it easy to hand carry
Support wake-on-LAN function
Support Green Ethernet
USB bus powered 3.3V/500mA
PC / Laptop / Tablet with free USB 3.2 Gen1 Port
Supported Operating Systems:
Windows 8.1, 10, Mac OS X
Product Name: Club 3D USB 3.2 Gen1 3-Port Hub with Gigabit Ethernet
Product Series: SenseVision
Weight: 51gr
Cable length: 100 mm
Item Code: CSV-1430
EAN Code: 8719214470111
UPC Code: 841615100217
Uplink: USB 3.2 Gen1 Male x1
Voltage
USB 3.1 Gen1 x 3 female
RJ 45 Ethernet port x 1 female
Driver CD
DOCKING STATION
