DisplayPort™ 1.4 to MiniDisplayPort  HBR3 Cable Male/Male 2M/6.56 Ft
CAC-1115 The Club 3D DisplayPort™ 1.4 to MiniDisplayPort HBR3 cable enables the connection of your DisplayPort™ supported source device to a monitor or other MiniDisplayPort supported device. It features a locking DisplayPort connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector.
This professional grade cable is ceritfied by Vesa.
Maximum resolution:
- 8K @ 60Hz
- 4K at 144 Hz
Without compression:
(DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz
Connector 1: Mini DisplayPort Male
Product Name: Mini DisplayPort to DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft.
Product Series: Accessories
Weight: 93 gr
Item Code: CAC-1115
EAN Code: 8719214470630
UPC Code: 841615100811
• Bi-Directional
• Vesa Certified
Operating System Support:
All
Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft.
