HDMI 2.0 4K60Hz UHD RedMere Cable M/M 15 m/49.21ft 28 AWG
The Club 3D CAC-2314 HDMI™ 2.0 4K60Hz UHD RedMere® Cable M/M 15 m/49.21ft 28 AWG enables the connection of your HDMI™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ supported device. It fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
RedMere® Technology
The CAC-2314 contains Active Chips with HDMI™ in-cable equalisation technology, with advanced signal processing allowing to support wide band data across relative thin and long cables while maintaining compatibility with the next generation of HDMI™ 2.0 devices.
Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
HDMI™ 2.0 4K60Hz UHD RedMere® Cable M/M 10m/32.81ft 28 AWG
Product Series: Cables
Product Code: CAC-2314
EAN code: 8719214470944
UPC code: 841615101139
• Compliant to HDMI™ 2.0 with Ethernet specification
• Professional quality braided cable with Metal connector head
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity
• Contains Active Chips with in-cable equalization techonology
• The CAC-2314 cable is Uni-directional
• All
• CAC-2314 HDMI™ 2.0 4K60Hz UHD RedMere® Cable
M/M 15 m / 49.21ft 28 AWG
• HDMI™ Male
• HDMI™ Male
• Cable length: 15 m / 49.21ft
• Box size: 21 x 21 x 7.5 cm / 8.27 x 8.27 x 2.96"
• Cable Weight: 1202 gr / 42.4 oz
• Box Weight : 112 gr. / 3.95 oz
• Total weight : 1314 gr. / 46.35 oz
Note:
This Club 3D HDMI™ * cable is also suitable for: Xbox One, Xbox One S, Xbox 360, PlayStation 4, PS3, Nintendo Switch * Please check your TV/monitor user-manual for its required specifications and maximum resolutions.
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
