CAC-2070 - The Club 3D CAC-2070 is an active HDMI™ 2.0 signal converter. The DisplayPort™ 1.2 to HDMI™ 2.0 4K 60Hz UHD Active Adapter is the easiest solution for connecting your DisplayPort™ 1.2 Game PC or Laptop to an HDMI™ enabled 4K UHD Television, monitor or Projector. The adapter is compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS through-put per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
The DisplayPort™ 1.2 to HDMI™ 2.0 4K60Hz UHD Active Adapter supports UHD resolutions of up to 4K UHD 4096x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your DisplayPort™ 1.2 enabled device in Ultra High Resolution. Supporting up to 8 channels of audio,the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/60 gameplay but lacks a native HDMI™ 2.0 output in their system configuration.
Product Name: DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter
Product Series: Adapters
Itemcode: CAC-2070
EAN code: 8719214470975
UPC code: 841615101160
• Compliant to DisplayPort™ Specification 1.2 for 1.62Gbps,2.7Gbps and 5.4Gbps per lane. Effective (video) bandwidth 17.28Gbps
• Compliant to HDMI™ 2.0 Specification, data rate up to 6Gbps per channel total throughput 18Gbps
• Supports 24-bit color and 4:4:4 color sampling
• Internal YCbCr 4:4:4 /4:2:2 to YCbCr 4:2:0 conversion capability
• Supports UHD resolutions up to 4096 x 2160p @ 60Hz and 1080p 3D
• Supports Nvidia® Maxwell cards and Intel® HD 5XXX series and newer. Not intended for older architectures.
Windows 10, 8.1
DisplayPort™ 1.2 Male
HDMI™ 2.0 Female
• Packaging size: 24 x16 x 1.5cm / 9.45 x 6.3 x 0.59"
• Poly Bag Weight: 8 gr
• Product: L210 x W44 x H14 mm
• Product Weight: 32 gr.
• Weight product with Poly Bag: 40 gr.
Club 3D DisplayPort™ 1.2 to HDMI™ 2.0 UHD Active Adapter
