Mini DisplayPort 1.4 to HDMI 2.0b HDR
CAC-1180 - The Club3D CAC-1180 is a Mini DisplayPort™ 1.4 to HDMI™ 2.0b active signal converter. It features support for HDR Video quality for deep color media content playback. The Mini DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0b. The CAC-1180 is downwards compatible to earlier Displayport™ and HDMI™ versions, but this can influence the functionality and/or supported features such as HDR.
Resolution Support
The CAC-1180 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the Mini DisplayPort™ and HDMI™ link bandwidth. The CAC-1180 also supports pixel encoding conversion from RGB or YCbCr 4:2:2 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:2:2 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Mini DisplayPort to HDMI Passive Adapter
Product Name: Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
Product Series: Adapters
Itemcode: CAC-1180
EAN code: 8719214470869
UPC code: 841615101054
• Video Stream Handling
- RGB/YCbCr 4:2:2/4:2:0 pixel format
• Audio Stream Handling
• HDCP Support
- HDCP 1.3 to HDCP 1.4 repeater function
- HDCP 2.2 to HDCP 1.4 and 2.2 repeater Function
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0b
- 4K 60Hz YCbCr 4:2:0, up to 12bpc
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc
Mini DisplayPort™ 1.4 male
HDMI™ 2.0b female
Windows 10, Apple OS X
• Boxsize: 182 x 60 x 35mm.
• Cable: 184 x 20 x 11 mm.
• Weight: 30 gr.
Club 3D Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
POSSIBLE RESOLUTIONS
