CAC-1211 - The Club 3D CAC-1211 is a DVI to HDMI™ 1.4 Adapter Cable. Because this Adapter Cable is fully Bi-Directional, it can also be used as a HDMI™ to DVI Adapter Cable.
This CAC-1211 Cable is the easiest solution for connecting your HDMI™ Monitor, Projector or Television to the DVI output of your PC / Notebook or to connect your DVI Monitor, Projector or Television to the HDMI™ output of your PC / Notebook / Game Console.
The CAC-1211 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to UHD / 3840 x 2160 at 30 Hz.
Model: |
Product Name: DVI to HDMI™ 1.4 Cable M/F 2m/6.56ft Bidirectional |
Product Series: Cables |
Itemcode: CAC-1211 |
EAN code: 8719214471040 |
UPC code: 841615101238 |
• Compliant to HMDI™ 1.4 Specification |
• Compliant to DVI-D Dual Link specification |
• Supports resolutions up to UHD / 3840 x 2160 at 30 Hz. |
• Fully Bidirectional |
• No external power needed |
• Plug & Play |
All |
• CAC-1211, DVI to HDMI™ 1.4 Cable M/F 2m / 6.56ft, Bidirectional |
• DVI Male |
• HDMI™ 1.4 Female |
• Box size: 145 x 145 x 45 mm. |
• WEIGHT PRODUCT(gr) 101 |
• WEIGHT BOX(gr): 51 |
• WEIGHT PRODUCT WITH BOX (gr): 156 |
• Cable length (mm) 2000 |
• Cable length (ft) 6.56 |
• Cable height (mm) 14 |
• Cable width (mm) 39 |
• Made in China |
