Mini DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft.
CAC-1182 - The Club3D CAC-1182 is a Mini DisplayPort™ 1.4 to HDMI™ 2.0b signal converter cable. It features support for HDR Video quality for deep color media content playback. The DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0b.
Supports up to 4K UHD Resolutions
The CAC-1182 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the DisplayPort™ and HDMI™ link bandwidth. The CAC-1182 also supports pixel encoding conversion from RGB or YCbCr 4:2:2 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:2:2 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Mini DisplayPort 1.4 to HDMI 2.0b HDR
Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter Male/Male 3M / 9.84Ft
Product Name: DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft.
Product Series: Cable
Itemcode: CAC-1182
EAN code: 8719214471217
UPC code: 841615101405
• Video Stream Handling
- RGB/YCbCr 4:2:2/4:2:0 pixel format
• Audio Stream Handling
• HDCP Support
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0b
- 4K 60Hz YCbCr 4:2:0, up to 12bpc
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc
Mini DisplayPort™ 1.4 male
HDMI™ 2.0b male
Windows 10/8.1, Apple OS X
• Box size: 145 x 145 x 45mm.
• Box Weight: 49 gr.
• Product Weight: 88 gr.
• Product height: 11mm.
• Product width: 22mm.
• Product Length: 2 meter/ 6.56 feet
