USB Type C to VGA Active Cable M/M 5m/16.40ft
CAC-1512 - The Club 3D CAC-1512 enables the connection of your USB C Supported Computer to a VGA Supported monitor or projector. This is an all in One Solution Cable and Adapter with the reversible USB C connector. Its necessary for the computer to support DisplayPort Alt mode from the USB C connector.
It allows Widescreen Ultra Extended Graphics Array (WUXGA) at a 16x10 aspect ration with a display resolution of 1920x1200 pixels which makes it a great solution for home, office or other work environments.
This USB C to VGA cable works with USB C Devices such as Macbook, Macbook Pro, Chromebook, Dell XPS, Asus Tablet, and Razer.
Product Name: |
USB Type C to VGA Cable Male/Male 5m/16.40ft |
Product Series: Cables |
Itemcode: CAC-1512 |
EAN code: 8719214471231 |
UPC code: 841615101436 |
• Supports DP1.1 Specifications |
• Supports MainLink 1Lane HBR (High Bit Rate)at 2.7Gbit/s per lane and 2 lanes at RBR (Reduced Bit Rate) 1.62Gbit/s per lane |
• This cable is USB powered and consumes approximately 200mW of power for video streaming in WUXGA |
• Supports Analog RGB Current source outputs |
• Supports 3.3V VSYNC and HSYNC outputs |
• Pixel Clock up to 240Mhz |
• Triple 8 Bit Digital to Analog Converter (DAC) |
• Supports 6, 8 Bits per color |
• Supports RGB formats |
OS Support: All |
• Club 3D USB Type C to VGA Cable Male/Male 5m/16.40ft |
• USB Type C Male |
• VGA Male |
• Box size: 14.5 x 14.5 x 6 cm. |
• WEIGHT PRODUCT(gr)245 |
• WEIGHT BOX(gr): 64 |
• WEIGHT PRODUCT WITH BOX (gr): 309 |
• Cable length (m) 5 |
• Cable length (ft) 16.40 |
• Cable height (cm) 1.4 |
• Cable width (cm) 3.5 |
• Made in China |
2013 USB 3.1 Gen 2 Super Speed + SS+ 10Gbps SS/HS/FS/LS
