DisplayPort 1.4 Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional M/F 3m/9.84ft
CAC-1023 - The Club 3D DisplayPort™ 1.4 Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional Male/Female 3m/ 9.84ft 28AWG Cable enables the extension of your connection to your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector.
The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 28AWG and fully Bi-Directional.
DisplayPort 1.4 HBR3 Extension Cable 8K60Hz M/F 2m/6.56ft
DisplayPort to Dual Link DVI-D HDCP ON version Active Adapter M/F
Product Name: DisplayPort™ 1.4 Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional Male/Female 3m/ 9.84ft 28AWG
Product Series: Cable
Itemcode:CAC-1023
EAN code: 8719214471392
UPC code: 841615101573
• The Cable is 28AWG and fully Bi-Directional
• Club 3D DisplayPort™ 1.4 Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional Male/Female 3m/ 9.84ft 28AWG
• DisplayPort™ 1.4 Female
• DisplayPort™ 1.4 male
• Box size: 14.5 x 14.5 x 4.5 cm
• Box size: 5.7 x 5.7 x 1.77 inch
• Cable: 300 x 2 x 1 cm
• Cable: 118.1 x 0.8 x 0.4 inch
• Cable Weight: 195 gr./6.88 oz.
• ESD bag: 5 gr. / 0.17 oz.
• Retail box incl. cable and ESD, 244 gr. / 8.6 oz.
