Mini DisplayPort to DisplayPort1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR M/F 1m/3.28 ft
CAC-1121 - Club 3D Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to any standard DisplayPort cable to extend the distance to your DisplayPort™ supported Television, Monitor, Projector or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 32AWG and fully Bi-Directional.
Mini DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft.
Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter M/M 3m/9.84Ft
Product Name: Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR M/F 1m/3.28ft 32AWG
Product Series: Cable
Itemcode: CAC-1121
EAN code: 8719214471408
UPC code: 841615101580
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, HDR 32.4Gbps
• The Cable is 32AWG and fully Bi-Directional
• Club 3D Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR M/F 1m/3.28ft 32AWG
• Mini DisplayPort™ 1.4 Male
• DisplayPort™ 1.4 female
• Carton Box size: 14.5 x 14.5 x 4.5 cm.
• Carton Box size: 5.7 x 5.7 x 1.77 inch
• Retail Box Weight: 24 gr. / 0.85 oz.
• Cable Weight: 42gr. / 1.48 oz.
• LDPE Bag: 5 gr. / 0.17 oz.
• Total Weight: 71 gr./ 2.5 oz.
• Cable: 100 x 2 x 1 cm
• Cable: 39.37 x 0.8 x 0.4 inch
