MiniDisplayPort 1.2a to Dual Link DVI-D Active Adapter
CAC-1130 - The Mini DisplayPort™ + USB Type A (for Power) to Dual Link DVI signal format converter seamlessly connect Mini DisplayPort™ based source to conventional DVI displays, such as CRT, LCD monitors and projectors, you can enjoy the ultimate widescreen canvas with a resolution of 2560 x 1440 @ 60Hz and up to 3840 x 2160 @ 30Hz on any other capable display.
Product Name: Mini DisplayPort™ to Dual Link DVI Active Adapter |
Product Series: Adapter |
Itemcode: CAC-1130 |
EAN code: 8719214471385 |
UPC code: 841615101566 |
• Support Mini DisplayPort™ 1.2a input and Dual Link DVI or Single-Link DVI output. |
• Support Dual-Link DVI highest video resolution to WQXGA 2560 x 1600 @ 60Hz * For Apple users see Checklist under Download |
• Support Dual-Link DVI highest video resolution 3840*2160 @ 30Hz |
• Support Single-Link DVI highest video resolution 1920 x 1080 |
• Support deep color 24bit |
• Powered from DisplayPort™ source and USB Type A Port. |
All |
• Club 3D Mini DisplayPort™ to Dual Link DVI Active Adapter |
• Mini DisplayPort™ Male |
• USB Type A power Male |
• DL DVI Female |
• Box size: 14,5 x 14,5 x 4,5 cm |
• Box size: 5,51 x 5,51 x 1,57 inch |
• Adapter size: 1,4 x 6,1 x 8,3 cm |
• Adapter size: 0,39 x 2,36 x 3,15 inch |
• Cable length: approx. 60 cm / 23,62 inch |
• Device Weight: 109 gr. / 3.84 oz. |
• Box Weight: 64 gr./ 2.26oz. |
• Total Weight: 173 gr. 6.1 oz. |
- SPECIFICATION_SHEET_CAC-1130_EN.pdf
- SPECIFICATION_SHEET_CAC-1130_DE.pdf
- CHECKLIST-CAC-1010+CAC-1130+CAC-1510 EN-DE-ES.pdf
- CHECKLIST-CAC-1010+CAC-1010-A+CAC-1130+CAC-1510-1510-A A6 EN.pdf
- CHECKLIST-CAC-1010+CAC-1010-A+CAC-1130+CAC-1510-1510-A A6 DE.pdf
- CHECKLIST-CAC-1010+CAC-1010-A+CAC-1130+CAC-1510-1510-A A6 ES.pdf
- CHECKLIST-CAC-1010+CAC-1010-A+CAC-1130+CAC-1510-1510-A A6 JP.pdf
