USB Type C to DisplayPort 1.4 8K30Hz HBR3 Active Adapter
The CAC-1567 Club 3D USB Type C to DisplayPort™ 1.4 Adapter 8K60Hz provided the source supports DSC1.2 HBR3 allows you to connect any USB Type C source to DisplayPort™ display at max 8K60Hz resolution and HDR support.
It works on any USB Type C host that supports DP 1.4/DP 1.2 Alt mode, resolutions are limited to the source device. When working on Thun- derbolt™ 3 host, this product transmits DP signal.
The soft UltraFlex jacket protects the cable from bends and deforma- tion damage. The Cable is 34AWG and Uni-Directional.
USB 3.1 Gen2 Type-C to Type-B Cable M/M 1m/3.28ft
Product Name: USB Type C to DisplayPort™ 1.4 Adapter 8K60Hz DSC1.2 HBR3
Product Series: Adapter
Itemcode: CAC-1567
EAN: 8719214471460
UPC: 841615101641
• Supports USB Type C input and DisplayPort™ output
• Supports DisplayPort™ resolutions up to [email protected] HDR, provided the source supports DSC1.2 and DP Alt-Mode 1.4
• Supports DisplayPort™ 1.4/1.2 Alt mode
• Compliant to Thunderbolt 3 specifications
• Supports per lane data rates of 8.1Gbps(HBR3), 5.4Gbps (HBR2), 2.7Gbps (HBR) and 1.62Gbps (RBR)
• Support up to 48 bit (16bit per channel) deep color
• Supports content protection of HDCP1.4 & HDCP 2.2
• USB bus power (no external power supply)
All
• CAC- 1567 USB Type C to DisplayPort™ 1.4 Adapter 8K60Hz DSC1.2 HBR3 22cm/8.66 inch, 34AWG
Available Interfaces:
Input: USB Type C Male
Output: DisplayPort™ 1.4 Female
Carton Box size: 24 x 6 x 3.5 cm / 9.54 x 2.36 x 1.38 inch
- Cable Size: 22 cm/8.66 inch
USB Type C connector : 2.2 x 0.7 x 1.3 cm / 0.87 x 0.3 x 0.5 inch
DisplayPort Connector : 5.4 x 1.1 x 2.2 cm / 2.2 x 0.43 x 0.87 inch
- Cable Weight: gr. / 1.48 oz.
- LDPE Bag: 5 gr. / 0.17 oz.
- Retail Box Weight: XX gr. / XX oz.
- Total Weight: XXgr./ XXoz.
Meets ROHS, FCC, and CE EMI requirements
