HDMI to DisplayPort 4K60Hz M/F Active Adapter
The Club 3D CAC-1331 is an HDMI™ to DisplayPort™ 1.2 Active Adapter which allows you to transmit a HDMI™ signal into a DisplayPort™signal. This product supports DP1.2 specification with resolution up to 3840 x 2160@60Hz. Besides, it is equipped with USB Type A port to supply power in case there isn’t enough power from the HDMI™ source. This Adapter is Uni-Directional.
Please use one of our (Extension)HDMI™ and/or DisplayPort™ cables
to connect from the adapter to your devices: In case you need
assistance to choose the correct cable, please visit our website
www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Product Name: CAC-1331 - HDMI™ to DisplayPort™ 1.2 4K60Hz M/F Active Adapter |
Product Series: Adapter |
Itemcode: CAC-1331 |
EAN code: 8719214471484 |
UPC code: 841615101665 |
• HDMI™ 2.0 support: |
- HDCP1.4/2.2 |
- 8/10/12-bit Deep Color |
- Status and Control Data Channel (SCDC) |
• DisplayPort™ 1.2 support: |
- DP1.2a compliant |
- Resolution up to 4K60Hz |
- Support Four Lanes with 1.62Gbps (RBR), 2.7Gbps (HBR) or 5.4Gbps (HBR2) Data Rate |
- Support 8/10/12-bit Deep Color |
- Support Hot-Plug Detect |
• Gold plated connectors |
Windows |
• CAC-1331 - HDMI™ to DisplayPort™ 1.2 4K60Hz M/F Active adapter |
• 1x HDMI™ (Male) |
• 1x USB Type A for power |
• DisplayPort™ 1.2 (Female) |
• Box size 14.5 x 14.5 x 3 cm |
• Box size: 5.7 x 5.7 x 1.2 inch |
• Device size: 2 x 1.1 x 25 cm |
• Device size: 0.8 x 0.4 x 9.84 inch |
• Device Weight: 38 gr / 1.37 oz: |
• Total Cable length 25 cm / 9.84 inch |
• Connector dimensions : |
• HDMI™ Male 4.8 x 1.1 x 2.1 cm / 1.89 x 0.43 x 0.83 inch |
• DisplayPort™ Female 2 x 3.5 x 1.1 cm / 0.79 x 1.38 x 0.43 inch |
• USB Type A Male 3.7 x 0.7 x 1.5 cm / 1.46 x 0.28 x 0.6 inch |
• Box Weight: 45 gr / 1,59 oz |
• Total Weight: 83 gr / 2.29 oz |
- SPECIFICATION SHEET-CAC-1331_EN.pdf
- SPECIFICATION SHEET-CAC-1331_DE.pdf
- SPECIFICATION SHEET-CAC-1331_ES.pdf
- SPECIFICATION SHEET-CAC-1331_JP.pdf
