USB Type C + HDMI™ + MiniDisplayPort™ 1.2 to HDMI™ 4K60Hz HDR M/M Active Adapter 32AWG
The Club 3D CAC-1630 is a perfect solution for any meeting room. This adapter will let you connect laptops/tablets/phones that support HDMI™, MiniDP™1.2 and / or USB Type C* video ports to your HDMI™ 4K60Hz ready projector, TV or monitor.
When all three inputs (USB Type C*, HDMI™ and Mini DP™) are connected simultaneously, the default display order is:
USB Type C* --> HDMI™ --> Mini DP™.
- USB Type C* to HDMI™ supports up to 3840x2160 @ 60Hz display resolution
- HDMI™ to HDMI™ supports up to 3840x2160 @ 60Hz display resolution
- MiniDP™ to HDMI™ supports up to 3840x2160 @ 60Hz display resolution
Please use the supplied Micro USB to USB Type A cable for powering this unit.
Support Plug-and-Play, no additional driver/software needed. For HDR to work please make sure the source support DisplayPort 1.4
This Adapter is Uni-Directional.
Please use one of our HDMI™, USB Type C and/or Mini DisplayPort™ (Extension) cables to connect from the adapter to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
* When using USB C port please make sure your device supports DisplayPort Alt mode for it to work.
Mini DisplayPort 1.4 to DisplayPort Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional F/M 1m/3.28ft
Product Name: CAC-1630 USB Type C* + HDMI™ + Mini DisplayPort™1.2 to HDMI™ 4K60Hz HDR M/M Active adapter 32AWG
Product Series: Adapter
Itemcode: CAC-1630
EAN code: 8719214471521
UPC code: 841615101719
• Ideal multiple input meeting room device
• Triple input USB Type C*, HDMI™ and Mini DP™ all Male connectors
• Support for [email protected] on all 3 input ports
• Single HDMI™ output port for support up to 3840x2160 @ 60Hz display resolution
• USB Type A for Powering the unit(supplied in the box)
• CAC-1630 Active Adapter
• USB Type A to Micro USB for external power
• 1x HDMI™ (Male)
• 1x USB Type C* (Male)
• 1x MiniDP™ 1.2 (Male)
• 1x USB Type A to Micro USB for power
• 1x HDMI™ (Male)
• Box size: 21x 21 x 3 cm
• Box size: 8.3 x 8.3 x 1.2 inch
• Device size: 8 x 5.5 x 1.3 cm
• Device size: 3.15 x 2.2 x 0.5 inch
• Device Weight: 145 gr / 5.12 oz
• Output HDMI™ Cable length approx.: 200 cm / 78.8inch
• Input Cable Length approx.: 30cm / 11.8 inch
• Connector dimensions :
- HDMI™ Male 3.5 x 2 x 1 cm / 1.4 x 0.8 x 0.4 inch
- MiniDisplayPort™ Male 2.6 x 1.1 x 0.7 cm / 1 x 0.44 x 0.28 inch
- USB Type C Male 2.7 x 1.2 x 0.7 cm / 1.1 x 0.5 x 0.28 inch
• Box Weight: 75 gr / 2.65 oz
• Total Weight: 220 gr / 7.76 oz
* When using USB C port please make sure your device supports DisplayPort™ Alt mode for it to work.
