Ultra High Speed HDMI™ Certified Cable 4K120Hz 8K60Hz 48Gbps M/M 5m/16.4ft
The Club 3D CAC-1375 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
- HDMI™2.1 also supports Static and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club 3D CAC-1375 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Product Name: |
Ultra High Speed HDMI™ Certified Cable 4K120Hz 8K60Hz 48Gbps M/M 5m/16.4ft |
Product Series: Cable |
Product Code: CAC-1375 |
EAN code: 8719214472030 |
UPC code: 841615102266 |
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification |
• Professional quality cable |
• Low EMI emission |
• Gold plated connectors for maximum conductivity and 28 AWG |
• Enhanced gaming and media features |
• Color space BT.2020 with 10bits,12bits,16bits |
• Backwards compatible to earlier HDMI™ versions |
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz |
• Supports Enhanced Audio Return Channel (eARC) |
• Supports Static and Dynamic HDR Metadata |
• Support for VRR, QMS, QFT and Auto Low Latency Mode |
• All |
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M 5m/16.4ft |
Available Interfaces |
• HDMI™ Male |
• HDMI™ Male |
• Box size: 21 x 21 x 7.5 cm / 8.27 x 8.27 x 2.96" |
• Cable length approx.: 5m/16.4ft |
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39" |
• Cable Weight: 391 gr / 13.79 oz |
• Box Weight: 70 gr / 2.47 oz |
• LDPE Bag Weight: 9 gr / 0.32 oz |
• Total Weight: 470 gr / 16.58 oz |
Note: |
- CAC-1375_SPECIFICATION-SHEET_EN.pdf
- CAC-1375_SPECIFICATION-SHEET_DE.pdf
- CAC-1375_SPECIFICATION-SHEET_ES.pdf
