USB Type-C Gen2 Angled Adapter set of 2 up to 4K120Hz 240Watt EPR M/F
The Club 3D CAC-1528 USB Type-C Gen2 Angled Adapter set of 2 up to 4K120Hz 240Watt EPR M/F is a versatile set of angled connector adapters providing cable management solutions. With either- or both- connector adapters you can avoid blocking other ports on your host device. Also for displays with a USB Type-C input this can be an easy fix for not blocking other ports and/or bending cables. This set contains 1 of each adapters and are universal in their usage, Data, Video and Power Delivery up to 240W(48V/5A). The adapters are verified with Club 3D products to support up to 4K120Hz. Supports USB Gen2 up to 10Gbps of data speed.
Product Name: |
USB Type-C Gen2 Angled Adapter set of 2 up to 4K120Hz 240Watt EPR M/F |
Product Series: Adapter |
Product Code: CAC-1528 |
EAN code: 8719214472146 |
UPC code: 841615102372 |
• Left & Right 90 Degree Angled/ Upward & Downward Angled Design 1 of each |
• Easy connection of your host cable |
• Doesn't block your other ports |
• Supports up to 4K120Hz with 2 adapters(with Club3D products) |
• Minimal signal loss |
• Supports USB Gen2(10Gbps) |
• High speed data sync with 240W(48V/5A)Power Delivery charging |
Applications: |
• Cable Management |
Supported resolutions: |
• up to 4K120Hz(with Club3D products) |
• All |
• CAC-1528 USB Type-C Gen2 Angled Adapter set of 2 |
Available Interfaces |
• USB Type-C Male |
• USB Type-C Female |
• Box size: 6 x 7 3.5 cm / 2.36 x 2.76 x 1.38" |
• USB Type-C Adapter dimensions: see images on our website, scan the QR-code for quick access or visit: www.club-3d.com |
• Device Weight: 2x6 gr= 12 gr / 2x0.21= 0.42 oz |
• Box Weight: 34 gr / 1.2 oz |
• Total Weight: 51 gr / 1.8 oz |
- CAC-1528_SPECIFICATION-SHEET_EN.pdf
- CAC-1528_SPECIFICATION-SHEET_DE.pdf
- CAC-1528_SPECIFICATION-SHEET_ES.pdf
