DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/ 9.84ft
• HIGH PERFORMANCE: DP™ 2.1 Cable is designed for UHBR13.5-enabled DisplayPort™  devices; DP54™ supports 54Gbps for 8K120Hz video and higher refresh rates at lower resolutions; Flexible TPE jacket routes well in tight spaces and withstands up to 120-degree bends
• FULL DP™ COMPATIBILITY: The VESA® Certified DP™ 2.1 Cable enables seamless compatibility with DisplayPort™  devices; Full-featured DP™ 2.1 performance and backward compatibility with DP™ 2.0/1.4/1.2 are guaranteed
• QUALITY CONSTRUCTION: Nickel-plated ends rated beyond 10,000 insertions; Latching DP™ connectors w/strain reliefs prevent accidental disconnection; Braided aluminum shield for enhanced EMI protection; TPE jacket is durable, halogen-free, and RoHS compliant
• VERSATILE PERFORMANCE: DisplayPort™  2.1 DP54™ supports 54Gbps across four UHBR13.5 (13.5Gbps) lanes to enable consistent high throughput; Ideal for 8K displays, high performance GPUs, MST multi-monitor daisy chains, and docking stations; Supports 32-ch audio
• SPECS: Black; 9.84 ft (3 meter); DisplayPort™  2.1 supports UHBR10-13.5/ HDR/MST/DSC 1.2/HDCP 2.2; DP54™ (54Gbps); 8K120Hz/DSC; 32-ch Audio; Compatible w/DP™ 2.0/1.4/1.2; Latching DP™ Connectors; 26AWG; 6.5mm (0.26in) O.D.
 The Club 3D CAC-1093 DisplayPort™ 2.1 VESA® Certified DP54™ Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 2.1 UHBR10/13.5 up till 54 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32
DisplayPort 1.4 to HDMI 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft
DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.6m/5.25ft
Product Name: DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/9.84ft
Product Series: Cable
Product Code: CAC-1093
EAN code: 8719214473259
UPC code: 841615103508
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5 up till 54 Gbps
• DP54™ Compliant, VESA® Certified
• Downwards compatible to older DisplayPort™ standards
• Support resolutions up to 8K120Hz or 4K240Hz
• Fully Bidirectional
• Windows 10 or upwards, macOS 15.0
• 1X CAC-1093 DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/ 9.84ft
Available Interfaces:
Input: DisplayPort™ 2.1 Male
Output: DisplayPort™ 2.1 Male
• Box Size approx.: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77in
• Cable length approx.: 3m/ 9.84ft
• Connector dimensions approx.: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25in
• Product Weight: 198gr / 6.98oz
• Box Weight: 63gr / 2.22 oz
• Bio Degradable Bag size approx.: 28 x 25 cm / 11 x 9.84in
• Bio Degradable Bag Weight: 4 gr / 0.14 oz
• Total Weight: 265gr / 9.35oz
