Mini DisplayPort 1.4 to HDMI 2.0b HDR
CAC-1180 - The Club3D is a Mini DisplayPort™ 1.4 to HDMI™ 2.0b signal converter. It features support for HDR Video quality for deep color media content playback. The Mini DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0b.Supports up to 4K UHD Resolutions. The CAC-1180 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the Mini DisplayPort™ and HDMI™ link bandwidth. The CAC-1180 also supports pixel encoding conversion from RGB or YCbCr 4:2:2 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:2:2 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Product Name: Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter |
Product Series: Adapters |
Itemcode: CAC-1180 |
EAN code: 8719214470869 |
UPC code: 841615101054 |
Windows 10, 8.1, |
Apple OS X |
• Club 3D Mini DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter |
• Mini DisplayPort™ 1.4 male |
• HDMI™ 2.0b female |
• Box size: 182 x 60 x 35mm. |
• Cable: 168.6 x 20 x 11 mm. |
• Weight: 30 gr. |
• Made in China |
• DisplayPort™ 1.4 Receiver, up to 5.4Gbps link Rate, HBR2/HBR/RBR |
• Video Stream Handling |
- Up to 600Mhz dual pixel path and 16bpc |
- RGB/YCbCr 4:2:2/4:2:0 pixel format |
- Horizontal expansion of Vesa CVT to CEA Timings (as per DP™ 1.4 spec) |
• DisplayPort™ to HDMI™ Stereoscopic 3D Transport |
- Frame Sequential to Stacked Top-Bottom Conversion |
- Pass-trough of ther 3D Formats |
• Audio Stream Handling |
- LPCM and compressed Audio encoding formats |
- Max audio sample rate of 192 Khz x 8 Channel or 768 KHz x 2 Channel |
• HDCP Support |
- HDCP 1.3 to HDCP 1.4 Repeater function |
- HDCP 2.2 to HDCP 1.4 and 2.2 Repeater Fucntion |
• HDMI™ transmitter |
- Compliant to HDMI™ specifications version 2.0b |
- 600MHz max TMDS character clock |
- High Daynamic Range (HDR) support both Static- and Dynamic HDR. |
- CEC Support - snooping, tunneling |
• Max Video resolution and color depth on HDMI™ output |
- 4K 60Hz YCbCr 4:2:2, up to 12bpc |
- 4K 60Hz YCbCr 4:2:0, up to 12bpc |
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc |
