DVI to HDMI™ 1.4  Cable Bidirectional M/M 2 m / 6.56 ft
The Club 3D CAC-1210 is a DVI to HDMI™ 1.4 Adapter Cable. Because this Adapter Cable is fully Bi-Directional, it can also be used as a HDMI™ to DVI Adapter Cable.
This CAC-1210 Cable is the easiest solution for connecting your HDMI™ Monitor, Projector or Television to the DVI output of your PC / Notebook or to connect your DVI Monitor, Projector or Television to the HDMI™ output of your PC / Notebook / Game Console.
The CAC-1210 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to UHD / 3840 x 2160 @ 30Hz.
Product Name: DVI to HDMI™ 1.4  Cable Bidirectional M/M 2 m / 6.56 ft
Product Series: Cables
Itemcode: CAC-1210
EAN code: 8719214471033
UPC code: 841615101221
• Supports resolutions up to UHD / 3840 x 2160 @ 30Hz
• Fully Bidirectional
• No external power needed
• Plug & Play
All
CAC-1210, DVI to HDMI™ 1.4  Cable Bidirectional M/M 2 m / 6.56 ft
• DVI Male
• HDMI™ Male
• Boxsize:14.5 x 14.5 x 4.5cm  /  5.71 x 5.71 x 1.77"
• Cable Weight: 104 gr / 3.67 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 154 gr / 5.43 oz
• Cable length approx.: 2 m / 6.56 ft
• DVI Connector dimensions: 5.2 x 4 x 1.6 cm / 2.05 x 1.57 x 0.63"
• HDMI™ Connector dimensions: 4.6 x 2.1 x 1.2 cm / 1.81 x 0.83 x 0.47"
POSSIBLE RESOLUTIONS
