USB Gen1 Type-C 6-in-1 Hub with HDMI 8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt
The Club 3D CSV-1596 is a USB Gen1 Type-C, 6-in-1 Hub with HDMI™8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt, providing an ideal solution for extending the port of Type-C/Thunderbolt host (PC/Laptop/Mobile phone,etc.), especially for those host with a single Type-C port. This hub adopts the latest DP1.4 Alt mode supported IC, enabling to output HDMI™ video with max. 8K30Hz-4K120Hz and at the meanwhile transfer USB 3.1 data with max 5Gbps. The USB Type-A and Type-C data ports allow you to connect 4 USB devices simultaneously. 1 Gigabit Ethernet for super fast Ethernet. Besides, the Type-C female supports PD 3.0 PD Charging 100W (15W is dedicated to the functioning of this product, the rest power(max 85W) will be passed to charge for the host. This 6-in-1 Hub will work on all DP Alt mode supported Type-C hosts.
CSV-1596 QUICK INSTALLATION GUIDE
USB 3.2 Gen1 Type-C 8-in-1 hub with 2x HDMI, 2x USB-A, RJ45, SD/Micro SD card slots and USB Type-C female port
Product Code: CSV-1596
EAN code: 8719214472344
UPC code: 841615102594
• Upstream USB Type-C Female:
 - Support DP1.4 Alt mode
 - Support HBR3
 - Support DSC1.1/1.2a or uncompressed video
 - Support DSC 1.1/1.2a decoder
 - Support 8/10/12 bit color depth
 - Support pixel format RGB/YCbCr4:4:4/YCbCr4:2:2/YCbCr4:2:0
 - Support positive and negative connection
• Downstream HDMI™ Female:
 - Support HDMI™ max 7680*4320@30HZ
 - Support HDMI™ max 4196(3840)x2160@120Hz
 - Support Dynamic HDR10+
 - Support HDCP1.4&HDCP2.3 specification
 - Support HPD
 - Support 8/10/12 bit color depth output
 - Support 1 to 32 channels LPCM 192kHz audio output
 - Supports HBR audio up to 1536kHz
Note: The output resolution, refresh rate, video pixel format depends on the performance of the computer and the monitor
• 2x USB Type-A Female
 1- USB Type-A port (next to HDMIHDMI™ port) supports max 7.5W([email protected]) downstream charging
 2- USB Type-A, second port support max 4.5W(5V@900mA) downstream charging
 Max 5Gbps bandwidth per USB Type-A port
• RJ45 (Gigabit Ethernet)
 -Support 10Mbps/100Mbps/1000Mbps
• USB Type-C Data Female(Close to USB-A port)
 - Max 5Gbps data transmission
 - Support 4.5W(5V@900mA) downstream charging
 - Support short-circuit, over-current, over-voltage protection
USB Type-C Female (for PD 3.0 Charging)
 - Support PD Charging 100W (15W is dedicated to the functioning of this product, the rest power(max 85W) will be passed to charge for the host
 - Support Fast Role Swap of PD 3.0, the connected device will not get disconnected while plugging in and out PD Adapter
• Windows and OSX
• CSV-1596 USB Gen1 Type-C, 6-in-1 Hub with HDMI™8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt
• 1x USB Type-C Male
 (Host connection)
• 1x HDMI™ Female
 for connecting to Monitor
• 1x USB Type-A Female
 Data
 Charging/Data
• 1x USB Type-C Female
 Data only
 PD Charging only
• 1x RJ45 Jack
• Box size 7 x 32 x 3.5cm / 2.76 x 12.6 x 1.38"
• Device size: 12.6 x 3.4 x 1.4 cm / 4.96 x 1.33 x 0.55"
• Total Length: approx. 30 cm /11.81"
• Device Weight: 89 gr / 3.14 oz
• LDPE Bag Weight: 5gr / 0.17 oz
• Box Weight: 42 gr / 1.48 oz
• Total Weight: 136 gr / 4.79 oz
Note:
