Ultra High Speed HDMI™ up to 240Hz 48Gbps Certified Cable M/M 7.5m/24.61ft
The Club 3D CAC-1378 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
HDMI™2.1 Increased Bandwidth to 48Gbps. The increase in maximum bandwidth compared to previous versions is achieved by increasing both the bitrate of the data channels (from 6Gbps to 12Gbps) and the number of channels (from 3 to 4). This allows support for resolutions up to 4K at 120Hz or 8K at 60Hz! All HDMI™2.1 features are fully supported by this Club 3D CAC-1378 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Product Name: Ultra High Speed HDMI™ up to 240Hz 48Gbps Certified Cable M/M 7.5m/24.61ft |
Product Series: Cable |
Product Code: CAC-1378 |
EAN-Code: 8719214473037 |
UPC-Code: 841615103294 |
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification |
• Professional quality cable |
• Low EMI emission |
• Gold plated connectors for maximum conductivity and 23 AWG |
• Enhanced gaming and media features |
• Color space BT.2020 with 10bits, 12bits, 16bits |
• Backwards compatible to earlier HDMI™ versions |
• Supports (U)HD resolutions up to 240Hz (with DSC 1.2) 48Gbps |
• Supports Enhanced Audio Return Channel (eARC) |
• Supports Static- and Dynamic- HDR Metadata |
• Support for Enhanced refresh rate features: |
• VRR, Variable Refresh Rate, reduces or eliminates lag, stutter and frame tearing for more fluid motion in games |
• QMS, Quick Media Switching for movies and video eliminates the delay that can result in blank screens before content is displayed |
• QFT, (Quick Frame Transport) reduces latency. |
• Auto Low Latency Mode |
• All |
Available Interfaces: |
• HDMI™ Male |
• HDMI™ Male |
• 1x CAC-1378 Ultra High Speed HDMI™ up to 240Hz 48Gbps Certified Cable M/M 7.5m/24.61ft |
• Box size: 21 x 21 x 7.5 cm /8.27 x 8.27 x 2.95 inch |
• Cable length approx.: 7.5m/24.61ft |
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39inch |
• Cable Weight: 790gr / 27.87oz |
• Box Weight: 70gr / 2.47oz |
• Bio Degradable Bag Weight: 4gr./ 0.14oz |
• Total Weight: 864gr / 30.48oz |
- CAC-1378_SPECIFICATION-SHEET_EN.pdf
- CAC-1378_SPECIFICATION-SHEET_DE.pdf
- CAC-1378_SPECIFICATION-SHEET_ES.pdf
