DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K120Hz, 8K60Hz or 10K60Hz M/M 1.6m/5.25ft
The Club 3D CAC-1092 DisplayPort™ 2.1 Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 2.1 UHBR10/13.5/20 up till 80 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connectors providing a secure, dependable connection, with NEW contact fingers special designed for these high speeds. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
DisplayPort 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K30Hz M/M 1.2m/3.94ft
USB Type-C to MiniDisplayPort Bi-Directional VESA DP40 Certified Cable M/M 2m/6.56ft
USB Type-C Cable to DP 2.1 Bi-Directional VESA DP80 Certified Cable M/M 1m/3.28ft
Product Name: DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.6m/5.25ft
Product Series: Cables
Product Code: CAC-1092
EAN-Code: 8719214473204
UPC-Code: 841615103454
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5/20 up till 80 Gbps
• DP80 Compliant
• New DP2.1 spec connector
• Downwards compatible to older DisplayPort™ standards
• Support resolutions up to 4K240Hz, 8K60Hz or 10K60Hz
• Fully Bidirectional
• VESA Certified
Supported resolutions:
Available Interfaces:
• DisplayPort™ 2.1 Male(NEW DP80 connector)
• 1x CAC-1092 a DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.6m/5.25ft
• Box size: 17.5 x 17.5 x 4.5cm / 6.89 x 6.89 x 1.77"
• Total Cable length approx.: 1.6m/5.25ft
• DisplayPort™ Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• Cable Weight: 166 gr / 5.85 oz
• Bio Degradable Bag size: 16 x 24 cm / 6.3 x 9.45"
• Bio Degradable Bag Weight: 1 gr / 0.04 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 230 gr / 8.11 oz
Note:
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432.
Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, feel free to mail us at [email protected] and it will be our pleasure to assist you.
  • No HR images found
