DisplayPort™ 1.4 to HDMI™ 4K60Hz Cable with HDR M/M 2 m / 6.56ft 32 AWG
The Club 3D CAC-1083 is a DisplayPort™ 1.4 to HDMI™ 4K60Hz Cable with HDR M/M 2m / 6.56ft converter. It features support for HDR Video quality deep color media content playback. The DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification.
The CAC-1083 supports up to 4096 x 2160p at 60Hz UHD resolutions.
Color Formats. It supports RGB/YCbCr video color formats with a color depth of 12bpc as long as it fits within the DisplayPort™ and HDMI™ link bandwidth. The CAC-1083 also supports HDR with deep color up to 12Bpc at 4K 60Hz is supported.
Note: For HDR to function, the source system needs to support DisplayPort 1.4 and the monitor needs to have support for HDR
Product Name: DisplayPort™ 1.4 to HDMI™ 4K60Hz Cable HDR M/M 2m / 6.56ft |
Product Series: Cable |
Product Code: CAC-1083 |
EAN-Code: 8719214473242 |
UPC-Code: 841615103492 |
• Support DisplayPort™ 1.4 input, HDMI™ output |
• DisplayPort™ 1.4 Receiver |
• HDMI™ Supports up to 4K60Hz, HDR |
• Support HDCP 2.2 |
• Support CEC |
Supported resolutions: |
• 4K60Hz |
• Windows 10 or upwards, macOS 15.0 |
Note: |
• For HDR to function, the source system needs to support DisplayPort 1.4 and the monitor needs to have support for HDR |
Available Interfaces: |
• DisplayPort™ Male |
• HDMI™ Male |
• 1x CAC-1083 DisplayPort™ 1.4 to HDMI™ 4K60Hz Cable HDR M/M 2m / 6.56ft |
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77inch |
• Cable length approx.: 2m / 6.56ft |
• Connector dimensions: |
• DisplayPort™ 3.7 x 1.94 x 1.38cm / 1.46 x 0.76 x 0.54inch |
• HDMI™ 4.32 x 2.08 x 1.1cm / 1.7 x 0.82x 0.43inch |
• Cable Weight: 68g / 2.4oz |
• Box Weight: 45gr. 1.59oz |
• Bio Degradable Bag size: 16 x 24cm / 6.3 x 9.45inch |
• Total Weight: 114gr / 4.02oz |
Note: |
Please update your TV Firmware to the version which supports these resolutions/refresh rates |
Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates |
- CAC-1083-SPECIFICATION-SHEET_EN.pdf
- CAC-1083-SPECIFICATION-SHEET_DE.pdf
- CAC-1083-SPECIFICATION-SHEET_ES.pdf
