USB Type C 3.2 Gen 1 Multi Stream Transport (MST)Hub DisplayPort1.4 Triple Monitor
CSV-1550 - The Club-3D USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor is an integrated solution that allow you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode. The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user’s visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station.
It’s the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that supports all DP Alt mode video signal output, for gaming and commercial applications. The MST Hub is directly powered from the host thru the USB Type C 3.2 Gen 1 connector.
Multi Stream Transport Hub DisplayPort 1.2 Dual Monitor to HDMI
SenseVision MST Hub USB 3.1 Gen1 Type C to DisplayPort™ 1.2 Dual Monitor
Product Name: USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor
Itemcode: CSV-1550
EAN code: 8719214471422
UPC code: 841615101603
• Compliant with DisplayPort™1.4 specification
• Compliant with HDCP 2.2 specification
• Supports dual [email protected] bpp without compression
• DSC 1.2 transport and up to 4-slice decompression
• High Dynamic Range (HDR) video
• SST or up to 3 stream MST
Microsoft Windows® 10
Mac OS® (only for DP1.2, no support for MST)
• CSV-1550, USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor
Available Interfaces:
• 1x USB Type C 3.2 Gen 1 for connecting to Host
• 3x DisplayPort™ Female for connecting to monitors
• Box size: 14.5 x 14.5 x 4.5 cm
• Box size: 5.7 x 5.7 x 1.77 inch
• Device size: 7.9 x 7.9 x 1.7 cm
• Device size: 3.11 x 3.11 x 0.67 inch
• Cable to Host : 13 cm / 5.12 inch
• Device Weight: 58 gr / 2.04 oz
• LDPE Bag Weight: 5gr/ .17oz
• Box Weight: 24 gr / .85oz
• Total Weight: 87 gr / 3.06 oz
MULTI STREAM TRANSPORT
